Installing an expert x questions ....
hereismylife
Pa
Website
www.hereismylife.com
I just got a expert x last night. I was wondering if anyone here has any quick numbers so I can get this thing in. I am putting it in a 00 SXR 700.
I would like to get it in so I can try it out before the snow melts. I am pretty sure this will be my last 2 days to ride.
I did read here about putting it on a viper but not sure if this will work out the same.
http://www.totallyamaha.com/ExpertX_M10/Proaction_ExpertX_Install.htm
Also I do not have the plates to mount it. I am going to put home made plates on the inside.
Also does anyone know how I can get the back hole marked without using the stock plates. On figure 2 it does not show you how to get the back hole.
Anyone know the distance between the middle of the front bolt to the middle of the back bolt?
Also is there a place that I can down load a manual for this.
If you might have some info you could call me on my cell at 717 629 7237
thanks joe
update...
I am getting the plates and going to wait till next year to check the skid out
I am getting the inside and outside stock plates and go from there.
thanks joe
update..
I installed the ss outside brackets on the inside. My question is do I still need the inside small inner steel brackets also since I installed the ss outer brackets inside.
The big ss bracket should be as strong as the small steel brackets.
anyone know?
