Ignition Coils
vmadmax
Upstate NY
Do ignition coils every drop out, fade, don't produce as much or strong enough spark at higher RPM's? Still trying to track down my hesitations at 5000 rpm! :o| #$%&*
I thought i recognized the problem, but i read allot of threads so i wasn't
sure..lol
grab a digital meter and try doing some test on the coils first..
I have s set of good coils if you want them. 35 shipped. i bought them off a TY'er because I thought mine needed replaced. Ran the same with them so I know they are good.
I needed a stator.
Tod
I had the same thing happen.It would act like a plug was fouling and you would change the pplug and it would be fine sometimes from 2 mins to 30 mins and then act up again.Sometimes i would get mad and not change the plug and 20 mins later the cylinder would kick back in.So I took the coil off the pto cylinder the one thatw as acting up and swapped it with the center cylinder then the center cylinder was doing it so i figured out the problem.
