orlo
Totally rebuilding my "00" SRX, from the crank up. Any good suggestions on setting up & bleeding the oil pump?..I don't want another crank failure from not doing a small but crucial detail.. Also any other good suggestions on set up?...
In between carb #1/ #2 there is a hose with a bleed bolt,that hose
is for bleeding the pump,crack that open till oil comes out good then
close..
if i were you i would just run one tank of pre-mix through it at say 50:1
by the time that tank is out all the air will be pushed threw.
when your done make sure you check your settings as follows;
1-set idle
2-set throttle end play(2mm)
3-set oil pump cable free play to 22mm
in that order only!!!
close..
1-set idle
