How do you remove the Rear Spring on the shock?
viper7mi
Michigan
How do you remove the rear spring on the shock on a 03 Viper? I hear its a monster. Is there a tool to use to compress?
thanks
yes there are tools. but its possible without one. loosen the spring tensionthen compress the shock and remove the collar above the spring
dont kill yourself, take it to an auto shop, they have great spring compressors for struts, it will take them a few minutes to take it off and you will leave your adjuster nuts where they are.
