Phazer II TSS how to lower
montynormand
central minnesota
Might be putting a Phazer II on the ice ovals next season. How do I lower the TSS struts. Honestly I have not even picked up a sled yet, but just planning ahead. I dont know anything about the TSS struts
thanks
Monty
i lowered my exciter one time and this is how i did it, first i took the top of the canister off [ 4 bolts] inside you will see in the bottom, the spring is resting on a cap bushing of some sort, it looks like a sleeve withe a furl in the buttom for the spring to rest on. I cut around that sleeve to add to it with a pice of pipe the same diameter I think I added 2 inch to it and then weld it on so your furl {were the spring rest on} will sit 2 inch lower. that worked fine for me. hope that works for you. mike.
thanks mike. that does not sound to difficult. Now i just need to find a sled!!
Any of you guys thing a exciter 570 or the 540vmax will beable to run with the Mach Z? heard that 600 put out 102hp out of the crate
Bender Racing made lowering tubes for the T.S.S. !
"Any of you guys thing a exciter 570 or the 540vmax will beable to run with the Mach Z? heard that 600 put out 102hp out of the crate" Stock for stock probably not but,............ with a good clutch setup the Vmax540's Scream..... ! :) Visit http://www.vintagevmax.com/ for information !
