Larger top gear sprocket available?
apaconte
ma
I just put reverse in my 1996 600 XT 1-up, from a 1994 600 DX 2-up. It works fine but it has a 20 tooth top gear sprocket with dogs. Do they make a 21, 22, or 23 tooth, so I can get better mileage and perhaps slightly higher top end? Since it is no longer being used on a 2-up, I am thinking the gear ratio doesn't need to be so low?
ANGELO
774-641-5331
yes they do make taller gears.Them style are getting hard to find unless you go to a yami dealer.
I Also Need Tuning Specs For Putting Gyt Pipes On My 600 Xt 1996. Can You Help?
Are these just the regular 13 wide non-hyvo gears? If so i have at least a 23 tooth, probably a 21 and 22 as well.
