Can you put a bigger recoil in an SX?
valin
Val Caron, Ontario
Here's something I've never attempted, so I have a question. Can I put a bigger recoil on my SX bottom end? The 1108 is a nightmare to pull over with the 72mm stroke. I have searched the forum, but haven't found an answer.
Having never done it, it still seems doable. You have to mount the housing such that the drivers drive the shaft right is all. You will likely have to fab a adpater for the housing.
That said, a Viper recoil might actually fit without modification.
It will turn the engine over slower though.
