orlo
When I start reassembling my crank cases on my 700 SRX, Do I need to use any specialized sealant between the cases? My repair manual does'nt really say. I've done a lot of rebuilds, just not on the bottom ends of the triples.
Thanks..
Thanks..
I like yamabond,,ask your dealer about it...
http://www.yamaha-motor.com/outboard/apparel/apscitemdetail/3/123/all/1/359/detail.aspx
or
http://www.yamaha-motor.com/outboard/apparel/apscitemdetail/3/123/all/1/331/detail.aspx
or
redsnake3
yamabond is the best stuff ive ever used, just dont get it on your clothes cause it will never come off.
got that right..redsnake3 said:yamabond is the best stuff ive ever used, just dont get it on your clothes cause it will never come off.
fordsrx
some sell the yamabond 4, but the shop manual says yamabond 5
change_up
I guess yamabond is supposed to be some good stuff... but I have just used a typical anaerobic flange sealant from a local farm supply shop... whatever you do I definetly wouldn't put it back together dry.
Gezzz no!!!change_up said:whatever you do I definetly wouldn't put it back together dry.
change_up
lol... just thought stating the obvious couldn't hurt!
Yup
orlo
Thanks guys... I see in the manual, it does state "Yamabond 5"..
Use on the whole crank case ? One side only?
Good luck orlo..
orlo
Thanks Daman, I don't doubt my abillities to do it, just want to make sure it's done right!!
Right thats not what i meant...LOLorlo said:Thanks Daman, I don't doubt my abillities to do it
orlo
Yeah, I got it!!!
redsnake3
just needs a thin layer on one side of the cases. try not to get it on the bearings. the stuff is really stringy so be very careful. and dont squeeze the tube as it is really hard to stop once it starts. hope this is helpful and not just repetitive.
orlo
Thanks redsnake.. It all helps
woolyviper
you need the yamabond that never completely dries - either 4 or 5 - I've seen polaris and arctic cat mechanics used yamabond for crank cases.
Yea it's good stuff,i wouldn't use anything else...
