Will a 136 skid out of a warrior bolt right in to a viper? I'm looking at extending my viper and can get a newer 136" skid fairly cheap. Also, how tough would it be to modify my tunnel to fit a ski-doo 136 SC3 skid? I have access to one of these as well.
the warrior one will work but you will need the rear mounting measurements. mine is the same as my brothers viper proaction. the only difference is that the rear scissors on the skid are moved back at least 6" (didnt measure it).
why not just use rail extensions on your skid unless it is trashed?
redsnake3
i used 136 rails to do mine and had to move the rear mounts in the tunnel. i can help if needed.
Thanks redsnake for the offer... I'm considering extending my rails, but I may be able to pick up skid out of a warrior pretty cheap. Are the shocks or would the ride be any different from the viper skid? Redsnake, how much movement is required for the rear mounts? Thanks
