Where can i buy stiffer small rear suspension spring ?
MountainMax
Churchill Falls,NL, Canada
on my 2002 mmax i find the front shock in my rear suspension bottoms out way too easy with my 250 pound weight on there even in the stiffest position I need stiffer. Does Yamaha or anyone else make a stiffer spring or spring/shock setup????/
i found a ski shock spring off a sx will work and its a single rate and pretty stiff. or even the center spring of a sx or srx is stiffer i believe
