Testing a Exciter Mod.
Ike
Finland
Watercross racing Exciter Mod-new pics and more coming (Testing a Exciter Mod).
Longtracked , Camo 1,5 inch 14 wide track, Decker pipe etc. Also lots of weight reduction done.
View My Video
Ike
My brother did great job reduzing weight on that thing.
Took away e-start, changed skis, put the Decker pipe (stock must weight a ton!) on etc.
Ike
Modding Exciter continues, with new engine, pipe and carbs. Engine is modded vmax 600 twin, pipe Totaltek single and carbs 39.5 mm flatslides. I cant use twin pipes because those dont fit under EX hood.
Wiseco pistons
Modded head
Pipe
Ready
SJ,
Are you using the EX crank & case, or is it the entire Vmax motor? if it's the entire Vmax motor, how easy was the bolt-up - did you have to play around with the engine mounts?
A.
-Its entire motor
-Crankcase bottom is same, cover different because cylinders are different
- Engine mounts are excatly same because same crankcase bottom. So no problem.
- Check parts catalog, you will be amazed how much those engines have same parts.
-sami-
that brings back alot of great memories! know if i could only fit my viper motor under the hood? wow what a ride that would be!!!!
Samueljackson got a another Exciter. It had PSI twins in it, Bender cold air intake and a new track.
He took the pipes + stuff and redid them and fitted them to his watercross sled. Well, he also rides this one winter too..
Some pics..
Ike :rofl: :bling:
Want some snow......
Finally I got exciter ready for winter. Job after summer water driving is soooo big. Last mod what i made was new rear axle and rail extensions with bigger Bravo 195mm wheels.
heres little pic from phone
