mountainmaxrider
just needs to know if i get a 1.5 inch track. would it clear with 9 tooth sprockets? or would i need to upgrade to 8 tooth sprockets?
1.5" should clear 9 tooth drivers in a pro-action sled. No studs and remove any heat exchanger protectors and it will slide right in.
9801srx
yes it will fit I have acamoplast chalanger 1.5 on both of my srx's 121 and 141. just remove the tunnel and front heat exchanger protectors.
..SNAKEBIT..
use to have one on my Viper it fit fine. just remove protectors like they said
