I thought somewhere I had read the 79 SRX runs on 16:1 fuel ratio. Is this corrrect.
back then,yes. but that is pretty rich with todays oils
premix
What is a good mix to use with todays oil's then. Thanks
YAMMIEGOD3:16
AGAIN OPINIONS GALORE ON THIS. RUN YAMALUBE R AT 32:1 !!!!!! NO ISSUES (and use race gas. if not strait , mix with pump prem. ) 3:16 (yammie tony)
GP292Racer
I run 94 octane and synthetic oil at a 20:1 mix in my race sleds. It doesn't hurt to run a bit richer with synthetic oils since they burn cleaner than a conventional oil.
YAMMIEGOD3:16
GP, THE IDEA BEHIND SYNTHETIC OILS WAS TO LET YA RUN LEANER. BETTER PROTECTION AT A HIGHER RATIO. I TRYED AS FARR AS 80:1 IN MY 77 SRX WITH NO ISSUES. THIS WAS WITH 110 AND AMSOIL. 3:16 (yammie tony)
my engine is stock so it ran the best with 32to1 yamalube r and reg gas
GP292Racer
yes, you can run leaner with synthetic oils, but you can also run richer without harming your octane level, unlike regular oil
I run rich just to be safe, and it seems to work pretty well in my sleds
That mill is well protectedGP292Racer said:and synthetic oil at a 20:1
.YAMMIEGOD3:16
I WOULD BE VERY CAREFULL RUNNING TODAYS GAS IN THESE OLD MACHINES. I LEAVE IT AT THAT !!!!!!!!!! 3:16 (yammie tony)
In my 78 trail srx I run 93 with 50/1 torco oil. My race 77 114 VP with the same oil. Never had a problem with Torco.....Dean-o
YAMMIEGOD3:16
DEAN, HOPE ALL IS WELL BUD. THAT ALEXANDER SHOW WAS AWSOME. TIM BENDER SIGNED FOR ALL. HOPE TO SEE YA SOON. 3:16 (yammie tony)
