Base gasket question..
orlo
Grand Rapids Michigan
Do you guys use any sort of sealer on your base gaskets?...Bottom end is complete & am ready to start top end build..
I use a copper spray a gasket it makes them tacky.I know many people on here use it or alot of the original guys.It's made by permatex.
orlo said:
Will a good cleaning w/ mineral spirits do the job?,
No, mineral spirits won't tuch that stuff you need something tough like
aircraft stripper or carb cleaner and then even that stuff you need to soak
it and really scrap it to get it off, that carbon on these valves is nasty stuff.
i personally use aircraft stripper that stuff works great without taking off
the valve coating..
