Dave_Vmax600
102C
108C
108EXP
and on there website they have one called 108 4-PRO
108C
108EXP
Exciterfan
102C Light duty
108C Medium Duty
108EXP Heavy duty (used one on my 87 Exciter)
4 PRO Super Duty: actually has four towers and four primary weights rather than the typical three.
108C Medium Duty
Dave_Vmax600
i want to get one for my big bore vmax 700.
not sure which one i should get
it is obvious that the heavy duty one is the way to go my friend.
the pro model has 4 weights,more fooling around to get clutch just right set-up.
Exciterfan
You could probably get away with the 108EXP (nothing smaller). It's a solid clutch.
The 4 Pro would acually give you some more flexability in tuning. If I were you I would be calling Comet to discuss their recommended tuning options for you application and see what they have to say. They do have a tech support line.
Dave_Vmax600
anyone know how much a 4pro goes for?
Why
Why would you run that? What's wrong with a yamaha primary????
Madmatt
Madmatt
Dave_Vmax600
mines cooked
toydoc
IMO, a EXP will work super. The 4 pro will only cost more for no gain..
Junior
my dad has been running comet clutches since the early 80's, I'll ask him for ya. Anything in particular I should know about the application?
PZ 1
- Mar 12, 2005
Dave_Vmax600 said:mines cooked
Unless it is broken completely (shaft etc.) I think that rebuilding it would be the better (and cheaper) way to go. If it is beyond repair, I would go with another Yamaha. They are adjustable, easy to get parts for and at least as reliable as a comparable horsepower rated comet.
Dave_Vmax600
this isnt a trail sled though.....thats why im leaning more towards comet.
yamaholic22
A comet isn't really any better for that application than a yamaha clutch. The comet clutch does allow you to use polaris weights however if you desire (most polaris profiles are very similar to the 8DN-20's, great all around weight). The yamaha will probably go longer on a rebuild (although that may not be the case with a twin, the twins are hard on yamaha clutches). Personally i would go with whatever you can get cheaper in great shape.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
We make a kit so you can use polaris weight in the yamaha clutch.
Bruce
Bruce
