'98 vmax motor question
montynormand
central minnesota
got me a 98 vmax tc with a 700 tripple in it. bought it that way, I assume its just the sx700 motor. Last ride of the year, if I was above 1/2 throttle and let off suddenly and got back into it, the motor would act like it would miss fire and "ping". Let of the gas let it idle down below 5000, and all would be fine again.
I'm thinking TPS or something like that. Completly a new one to me... any suggestions?
The 98 700 triple is STD for that sled. The problem sounds like a TORS problem. You need to locate the wires going to the carbs. Unplug them ( 2 of them ) and plug them together coming from the harness leaving the leads from the carbs unplugged. Problem should be corrected. Good luck !
