Bender specs
Not sure about their springs, but they won't tell you jack about their helix angles. I'm willing to bet they take the same stance with their springs. Trade secrets!!!
Anything in particular you want to know? Someone might chime in if you describe a specific problem.
they advertise their spring rates ya. I had it all in a notebook once upon a time, I'll be buggered if I can find that notebook now tho, moved alittle while ago and haven't seen it since.
If I had it all written down tho, it's a good bet that srxspec or turk had it written down aswell.
Thanks junior, i will wait and see if one on them posts here. Yamerdown..somebody is selling some used springs on here and was just wondering what the specs were.
Mike
If all you need are preload and shift out Kg, and you know the colour of the spring and what its for, I might be able to help you out.
Jensen:
In Benders catalog the only one that comes close to that colour is one for a YPZ Clutch and is Orange/ Violet 27kg preload and 96 kg shift out. They also make a pre 98 YXR clutch spring that is Yellow/Purple 50 preload and 137 shift out. I can't find that colour combo in the catalog, unless it is someone else's or a special order from Bender. Sorry I could not be of better help.
Dave
