Hi!
I'm trying dragracing on gras thiss summer. I got a 780 bmp motor full race porting and hauck race pipes.. How much studs should i use? And what kind? gear setup? what helix? Setup in the rear suspesion?
Thanks Tommy
Thanks Tommy
it depends what kind of hp and what rpm's does it run at?Have you dynoed it?
The hauck race pipes usually run 9800 to 10,200 depending on your compression.
yamaholic22
You got a race box for that thing? If not you will definately need one with those pipes.
YAMMIEGOD3:16
MIKE, ON ITS WAY. THANKS. 3:16 (yammie tony)
Do you have a track yet?
I have a camoplast closed window 1/2 track with like new 240 chisels with aluminum angled backers I will part with.
if i remeber right i got 155 of comp. pipes 10000 rpm. iguess Hauck Howler pipes.. got a hauck 10000 rpm cdi.. 38 Mikuni from Mach Z. no track yet. what track should i use..?
pro116: How much for the track?
I Would Go With A Lower Rpm Pipes My Self.
at 155lbs of compression your peak hp will probaly be around 10,200rpm's.
I will try to get picks of the track 375.00 plus shipping it's in excllent shape.
