Want to put 136 into SRX...need parts!
kingtigg
Winnipeg, Manitoba
I've found a 136" track that I'd like to put into my '98 SRX.
I don't think I want to replace the rails due to the cost and the amount of work involved.
If I get rail extensions will I need to do any other work to the tunnel or hoses?
Assuming all I need are the rail extensions....does anyone have any used ones that will work for me that they would like to sell?
Thanks in advance!
-Kingtigg
I'm no expert, but I'm guessing you'll need to lengthen the tunnel, relocate the rear exchanger, and lengthen the hoses. Otherwise your flap will be in the track.
u will definately need a tunnel extension and get one that will take the rear heat exchanger. you will also need longer hoses and hose covers if you want it to look factory. it will be well worth it though
I would go with Tracksusa rail extensions and any tunnel extension that will take a heat exchanger. Hartman's probably does. Tracksusa rail extensions are WAY strong.
you can buy the tracks usa extension that works find you just need to message it a little. do a search on hose covers, i posted a link (www.wps-inc.com)that you can get them at for about $60 for the pair.
