Anyone have a problem with the inside ones hitting the rear pivot arm on big bumps? The sleds is a 98 SRX.
Thanks.
Thanks.
Had no problem with the 7.5" rears on my 2001 SXR.Am putting the same 7.5" on my 2002 SRX to.
bluewho
Transfer rods will bottom out before that arm will hit.
Hmm, perhaps the aftermarket transfer rods or the thinner nylon washers are the cause then. Thanks. There you go SNOW.
SNOWRULES
hahahahaha thanks yamerdown. think it's probably the washers being too thin and the rods being turned all the way up.
