Hey guys can you tell me if this is stock? the primary has a yellow dot on the spring and the secondary has a red dot, is this stock for the 2001.
Trail sled or not, put HC in it and forget about it. LOL
YAMMIEGOD3:16
PRIMARY SHOUND BE Y-W-YBenderSRX said:Hey guys can you tell me if this is stock? the primary has a yellow dot on the spring and the secondary has a red dot, is this stock for the 2001.
SECONDARY SHOULD BE RED. 3:16 (yammie tony)
Doesn't sounds stock, could be Bender parts? My Bender kit was a black secondary spring with a silver dot on it (for my Viper, so different colour) and a yellow primary was an orange dot.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
Put a 54/42...40 if you are over 225# helix and a red spring 3-3.....and the stock spring Y-W-Y. You will be very happy.
Bruce
Bruce
YAMMIEGOD3:16
HEY BRUCE QUESTION FOR YOU. HOW YOU EVER MAKE OUT RUNNING THOSE POWER inc. PIPES ON YOUR SRX. 3:16 (yammie tony)
Hey guys thanks for helping me, just to clarify on the primary spring Y-W-Y, i would see yellow,white and yellow altogether?
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
3:16...... saw better midrange and maybe 2 or3 mph topend. We will do more clutching next season.
YAMMIEGOD3:16
NOW THEY THE SAME PIPE VALIN IS SELLING. ALSO ARE YOU USEING STOCK CYLINDERS WITH THESE PIPES. 3:16 (yammie tony)
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
stock cylinders....and Yes I think they are the same
