Viper Slider change
VIPDHEMI
St.Clements Ont.
Ok so I changed my sliders which is normally an easy job...But I forgot to shave the back of the sliders on an angle. When I put my Viper into reverse am I gonna peel my sliders off? I can take the rear wheels off if needed and file an angle on the sliders but I was wondering if I need too.Thanks
Pull the screws out, stick a flat scredriver between the tip and slider and rotate the track by hand backwards (with the driver hooked on a window clip) and have it come through a track window at the rear and just cut it off at a angle and file clean, then reinstall...ready for season...
I replaced them through the track window with the suspension in. They should slide easy with all the graphite spray I put on them. I just was hoping that they would slide better the next time I changed them, well I guess I get to see if my graphite spray trick works a little earlier then expected lol.
