Anyone got the factory specs on the radius rods upper and lower.Manual shows something like in the 18" area,but mine are in the 20" range.The length is center to center of Heim joint to the other end. I have approx 20.25" showing on my uppers.I need to get the upper spec for sure and make the bottom rods the same length in order to get a 0 camber.
upper 424.2 mm , lower 417.7mm with out joint and installed length with joint 460.2 upper and 458.7mm lower
Thanks a lot MrSled for that info. When you say installed with joint,is that the entire length end to end or is that center of the holes in each end?
Never mind,I figured it out..it is center to center of the holes.So if I make both the upper and the lower the same lengths,that will give me 0 camber .With the Simmons ski's I will be installing,it says to make sure ski's are flat to the surface,both carbide runners touching at the same time,so camber must be neutral then,or at 0 camber.Anyways thanks again for the specs.
Correct.
