do u think a viper hood can fit on a srx with a little modification for the exhaust ????
no, it wont fit unless you change the bellypans too.
do u think belly pan can be change without any problem ???? or they need to be modify and every thing
you need
hood, bellypan, front hoop, uprights, cut the bellypan for outer pipe, bender can(or others) lower all three pipes to fit under hood,viper airbox(optional), and front bumper
thnxxx wow a big project to do lolllll..i hate the hood of the 98 99 srx ...... maybe ill try to find a 00 and up hood
sxviper32
are the hoods that different (98-99 compared to 00-01)? just do a sticker swap from 98-99 to 00-01
no light are not the same so its make a different look :-))
sxviper32
you can change the gauge pod without changing the hood. you can get a dual bulb pod and put it on and the you'll need the dual bulb headlight and windscreen. i do not know about the wiring part of it tho, you may wanna ask around about that part. do a search, a lot of people have done it.
thnx i was sure the hood was not the same too .....but the viper hood look awsome i wish i could have a tricky srxviper .... but it look to be a huge project and alots of parts
yam_apex91469
you need to change the stator, magneto and entire wiring harness to update to the 2000 or newer system. Wanted to upgrade my 99 but decided not to spend the time or money. Good lucksxviper32 said:you can change the gauge pod without changing the hood. you can get a dual bulb pod and put it on and the you'll need the dual bulb headlight and windscreen. i do not know about the wiring part of it tho, you may wanna ask around about that part. do a search, a lot of people have done it.
well i will not upgrade i will put lower watt bulb in it
yamaholic22
The bulbs are the same wattage as the single bulb headlights, its just that two are plugged in instead of one. You could just plug one of them in.
