SRX Clutching Question
ExpertXViper
Livonia, MI
Went threw my clutchs on my recently purchuse SRX found it set up with:
8BVFA 51/43 Helix, Green sec spring wrapped 6-3(90deg). Wh/Wh/Wh primary spring, and 8DN-20's with 4.5g rivets in both holes. Can someone explain to me a little about this set up? Weight / Ride Type
The seller notifed me about the clutch changes, I just dont know a whole lot about SRX's clutching.
Any help is appreciated!!!
EVERY THING I EVER READ, TRYED, AND SEEN ON A SRX WAS NO MORE THAN 8500. SOUNDS LIKE YOU HAVE NICE SET-UP THERE. 3:16 (yammie tony)
Your secondary is wound a little tight. You should gain some midrange by loosening it to 3&3
Thanks Turk.... 6-3 seemed like a bit much. Ill give 3-3 a whirl.
MODSRX: In english please, I dont quite get what your trying to say or ask.
