98srxPa
Looking for a clutch setup for mostly trail riding, everything is stock
I am not sure what i am looking for so post some killer setups, ty
seca
this seems to be what everybody is using. 8dn-20 weights with 4.5 gram rivits in each hole, w-w-w primary spring, 48-42 helix with green secondary spring. they say this setup rocks!!cheers, joe.
Turk
TY TECH ADVISER
- May 2, 2003
Do a Search on SRX clutching. You should be finished reading by Xmas.
yamaholic22
seca said:this seems to be what everybody is using. 8dn-20 weights with 4.5 gram rivits in each hole, w-w-w primary spring, 48-42 helix with green secondary spring. they say this setup rocks!!cheers, joe.
That 48-42 is an advant-edge helix. They are cut way different than others. If you dont want to get an advant-edge get a 52/44 or so from any other company, it will work very similarily.
