heavy hitters
They have really hard accelleration and great top speed set up right.If you do a search I poisted a set up for the srx.
BlueByYou2000 also had a very strong setup to use with the Heavy Hitters. Not sure if pro116 is referring to the same one, but you can make the SRX move with the right setup
BlueByyou2000 set up is very strong also he spent alot of time testing as well.We have slightly different primary set up's but the secondary is the same.
You can make the 48g ones work. You just have to throw a lot of weight at them to keep the rpms where they should be. That is the base weight I used with BBY's setup.
