99 m max 7oo adding triples
franko2176
muskegon mi
can any one tell me if the bender spec sheet is perfect for tuning the carbs when changing to triple pipes ? ihave done all the other mods for the sx motor any info would be great :bling:
There are different specs. I have done a skazillion Bender piped 700,s.
52.5 pilots
150 mains
Raise needles 1/2 right across.
Good to -15.
thanks for the info what clip position is that? do i still use the washers on top and bottom of needle thanks franko2176
Every sled is different. start at 2 out but don,t go more then 3 or the screws fall out & you won,t find em or even worse; impossible to buy em.
Thanks for the info,will it hurt to start at1.5 i always kill plugs jetted 1 size down and 1.5 turns out with stock pipe bender can always seems to run rich on low end. will i have to change the clutching it is perfect with stock pipe and bender can
