aftermarket secondary
duck57
fond du lac wi
Who has tried different aftermarket secondary clutches. What works best .Why is it better? Where is the best place to buy? :?: :?: :?:
Seems like alot of racers are going with the Team secondary for quick backshift and a couple more track HP. I've had great luck with the stock on and a Dalton helix, which helps it shift out further. I've seen too many exploded clutches to machine them though...
I have good luck with HI-TECH ER secondary set up. The beauty of it all is that you can easily adjust preload in seconds.
Maxximum Performace Roller Secondary
i have maxx performances roller secondaries on both my 00 600 sxr and 02 viper, love it, made a huge difference excellent backshift, very nice unit and easy to do urself or they will install it for like 30 extra bucks... maxximum performance is a great outfit... they will send the proper set up for ur sled and its mods...
secondary clutch
heard that you will loose top end with a team clutch
