aftermarket spring
jabber800
Coniston Ont.
Looking for an aftermarket primary clutch spring, with preload of higher than 45kg. and final force of around 128kgs. I am presently using the YWY long spring but require more preload. Does anyone make a spring near these specs????
THX Dan J.
Hey jabber800. For the best results you should post this in the yamaha classifieds under WANTED. Just tryin to look out for ya and get you some better feedback.
Chadg
jabber, Bender makes a Yellow/ Pink primary spring that is 50 preload and 127 total force, but it's for pre 98 YXR clutches, you will have to use their 8mm shim kit for it to work. Also they make a Orange spring that is 55 preload and 135 total force, you will have to use the shim kit with spring to. Hope this helps. Dave
Won't have any problem solving that one. Just be nice to get another test run in before the races on Sat. to make sure we get it close.
