venture700
im wondering if a 2003 rx-1 mountain (8 tooth) drive axle would fit on my 2003 venture 700 (9 tooth) because i got a 2 inch track comming.
that would be a no, shaft is shorter, and has no hole for speedo drive
cogs would work if you swapped onto your shaft
venture700
thanks. i forgot all about the digital speedo. yea ill try to put the 8 tooth sprockets on mine.
