Good Tether switch
nailsandrails
Northern, IL
Looking for suggestions on adding a tether switch to my 02 SRX. I went to a aluminum throttle block when changing to Apex bars and now I want to add a tether because I lost my kill switch. A lot of them seem cheap. Any ideas of something decent that will last? Also which wires to splice it into would be helpful. I'm assuming I can figure it our from the old connector, but if someone has already done it I would appreciate the info!!
DUDE, CALL BENDER RACING. I THINK THEIR $24.00. THEIR ALSO YAMAHA TETHER,S THAT ARE COLORED CODED TO YOUR WIRING. VERY SIMPLE TO ADD A TETHER, THE BENDER TETHER WILL HAVE A WHITE PLUG, JUST CUT THAT OFF. YOU DON,T NEED IT. THAN PULL YOUR HANDLE BAR PAD OFF AND TAP RIGHT INTO YOUR ENGINE KILL BUTTON. I BELIEVE WIRES ARE BROWN AND BLACK WITH WHITE STRIP. YOU WILL FIND THESE SAME COLOR WIRES IN HARNESS. THAN JUST MOUNT YOUR PLUG RIGHT NEXT TO THUMP WARMER. ITS ALITTLE TIGHT BUT PERFECT SPOT. MINE LOOKS FACTORY ON MY 02. DON,T FORGET WHEN YA TAP INTO SYSTEM, DROP SMALL BEAD OF SOTER ON CONECTION, THAN WRAP WITH ELECTRICAL TAPE. YOU WILL BE GOOD TO GO. 3:16 (yammie tony)
Been gone for 2 weeks on the road. Get me your address, and I'll send it right out. Sorry. Paul
