cannon3731
I have a 2000 sxr 700 and my brother has a 2002 polaris classic 600 ves twin.
What sled do think is going to be faster (both are stock) We both bought them this summer.
SX-R hands down!
CdnSxR6
HP is pretty close on those 2 sleds. If the sxr is stock it is going to over-rev. Clutch it and setup your suspension for your weight. It's not that costly and well worth it.
cannon3731
The primary sping has been changed to ywy. What do you suggest for the clutchsCdnSxR6 said:HP is pretty close on those 2 sleds. If the sxr is stock it is going to over-rev. Clutch it and setup your suspension for your weight. It's not that costly and well worth it.
Chgange inner rivet to a 4.5 gram & run a RX-1 helix.
ViperTom
cannon3731 said:I have a 2000 sxr 700 and my brother has a 2002 polaris classic 600 ves twin.
Faster-SX-R
Quicker-Poo600
If traction is about the same on both sleds (lug height, studs) the Poo will jump the SX-R on the holeshot but give it a couple hundred yards and the tripple should start to show its longer legs.
Tom
Yah, yah! Eaxctly what he ^^^^ said!
Yamahasrx700
Yak..Yak..Yak.. There is only one way to find out.
cannon3731
What do i need to do so the sxr dont over-rev?CdnSxR6 said:HP is pretty close on those 2 sleds. If the sxr is stock it is going to over-rev. Clutch it and setup your suspension for your weight. It's not that costly and well worth it.
I told you what to do. I owned 2 & clutched many many 700 sx-r,s!!!!
SWEDE
Take Turk's advice, its works, mine was like a different sled with those changes!Jet down to 142.5 mains straight acrossed, this makes a difference also.
cannon3731
Ok thanksTurk said:Chgange inner rivet to a 4.5 gram & run a RX-1 helix.
cannon3731
Thanks Turk What springs should i run? I have a ywy in thr primary and the stock in the secondary.Turk said:Chgange inner rivet to a 4.5 gram & run a RX-1 helix.
Run the stock primary spring for trail riding but the y-w-y for racing. Run the green stock secondary spring at 60 wrap. Drop main jets to 142.4 & drop the needles 1/2....both clips on top of shim.
Turk?
"both clips on top of shim"???? Do you mean both shims on top of clip?
Madmatt
Madmatt
SRX7
see clip postion 3 put washers above the clip, oposite of picture. But be very careful those little washers are so small you can loose then like that.
http://www.totallyamaha.com/snowmobiles/aaTECH/CarbNeedles/carbneedle2.jpg
