Bearings...What size and where to buy - Viper
viper7mi
Michigan
What is the size or number for the bearing on the front four wheels on a Viper? What wheels are replaceable?
Where can I get some and average cost? I read Napa sells them, how would I know if they are packed with low temp grease?
How do you take the bearing out if it is off the wheel?
Ron,
Best bet in our area is Rec. Leisure, they carry the Formula NTN low temp bearings and are at a decent price. If you just want to buy and replace with out digging for equivalents that is the place. If you can find these on-line cheap, let me know, always good to have some around, ha.
Al
Goodwin Performance lists these, about the same price as Rec Leisure but buying local avoids shipping cost. They seem to be pretty price fixed no matter where I have seen them...
NTN-6004
NTN Bearings
NTN Formula bearings have super finished raceways, special low temperature grease, premium hardened steel and blue double lip seals for the best cold weather bearing available.
Bearing Size- Priced Each
NTN 6004 20mm x 42mm x 12mm $10.75
NTN 6202 15mm x 35mm x 11mm $10.50
NTN 6204 20mm x 47mm x 14mm $10.50
NTN 6205 25mm x 52mm x 15mm $11.50
NTN 6206 30mm x 62mm x 16 mm $12.95
NTN AS 205-100 1" jackshaft $24.05
NTN AS205-014 7/8" jackshaft $24.05
