marinetech
Hi Everyone
I have checked this site alot and its been very helpful. Finally joined and my first question is this , I have a 04 Polaris xc600sp and wonderd if I could take the stock track off of this sled and put it it on my 98 srx 700. Hopefully someone can tell me if this will work without any problems.
Thanks , Dana
Thanks , Dana
NYsledneck
Sure you can as long as it`s not over a 1.25 lug height.
yes, you will want to take notice of of your tunnel protectors, they will hit the bars on a camoplast track. you will need to notch the track with a knife, very easy. if you have the u style guards on your sled, remove them and run them through the saw and make them an L . reinstall them so they line up with the front guards. this will allow you to make the notch much narower, thus leaving more lug for traction. pro action guards are designed around a 3/4in track, if you keep that in mind when cutting youll be fine and your speed wont suffer.
polaris came with a great camo track, very fast and light.
while you have the skid out read the article below to know what to look for on that skid.
good luck
scott
good luck
scott
viper48
My brother-in law put a 1-1/2" track on his 98 srx600. He had a dealer do it. I would assume that they just removed the guards on the heat exchanger with a grinder. Thats what they did with my viper.....I have a 1-1/4" on the viper...
blue missile
i run a 1" ripsaw track i bought off from cb performance last year it has polaris tatooed all over it.
