700sx
I have three megapower helixes can anyone tell me what the angels are on them one is a M-5 with 00JZ on it the other is M-1 with 00RB and the last is a M-4 with a 010B?
M1 - 56/38
M2 - 50/42
M3 - 56/40
M4 - 58/34
M5 - 58/42
M6 - 60/40
M7 - 60/38
M2 - 50/42
M3 - 56/40
M4 - 58/34
M5 - 58/42
M6 - 60/40
M7 - 60/38
700sx
Thank you srxspec that is a big help. Do they have a web site also?
Wow
Those are all some relatively steep starting angles!
Madmatt
Madmatt
700sx, I believe Megapower has been out of business since around 2003.
The numbers are high, but it is just a number. Every helix is cut differently and the said angles are not always the same as the number given to them.
700sx
What are these good for trail or racing?
To know what they are youd need to check the angles on a digital cad machine, this will tell you the true angles in which they are cut. Some places have numbers on thier helixs and the actual angles are either more or less then whats stamped on it, it all comes down to the quality of the cut and the radius in which they use to machine it. I had some megapower stuff in the past and they were on dalton helixs ,very accurate cuts. If for say those were dalton cuts and they were actually those angles that srxspec posted they would be race helixs for the most part, although a couple of them could be made to work for aggressive trail, would all depend upon the clutch componets used with them. I have the M5 helix and it can work good in a srx for grass drags.
