This may seem like a dumb question.
What color lock tight to use on the front four skid wheels? Blue or Red?
SWEDE
Blue would be fine which is the lower strength, but you probably don't need it because those are all lock nuts in the skidframe I believe.It does'nt hurt though, I mainly use it on the main bolt that attach the skidframe to the tunnel.
If you ever plan on taking them off again only use blue as the red will require heat most of the time.But as was stated above they are lock nuts anyway and really shouldn't need any but it never hurts.
