RIVERRUNNER
I just got back from haydays where I picked up a set of c&a skis and I just put them on my srx.  Do I need to do any adjustments, down pressure?  I am also wondering what model they are being that a stoled them off of a guy for 70 bucks and they look like they have about 100 miles on them.  I got the mounting kit from rich and a set of new carbides 6" carbides.  145 bucks later I am pumped for snow!!!!!!!  They are 6 inches wide and they have a large square keel.  They rest of the ski is flat.  I am wondering how they will affect the flowtation of my sled in snow and water???
			viper48
Sounds like I have that same ski you are talking about. I have a 6" carbide on them and to me that is not enough. I think I will try the shaper bar from studboy. I am likely going to try a 7.5"ish carbide. I guess I have never changed my set-up for my sled when tryng a new ski, just put'em on and go. My next set of skis might be a pair of simmons skis. Who now's......I went to haydays on Saturday....good crowd......saw Pat Hauk run a couple of rounds at the grass drags......Always fun to see an old v-max still kicking butt!!!
			RIVERRUNNER
Do you know the model of the skis you have???
			viper48
advantage ski
			richierich
yep those are advantedge ( ad ) models.just bolt them on and go as long as your skis point straight your good.
			yamaholic22
I really loved my sets of C&A's. Love the way they rail the corners, and love how they look. Also EVERYONE has carbides for them because it is such a popular ski. Other aftermarket skis can be much harder to get carbides for. Only change you may need with the C&A's is a change in ski pressure, but that can only be determined after riding it.  Letting out the limiter/tightening center spring will take weight off the skis, as well loosening the front preloads.
			Danger Dog
I had a set of C&A's on my srx with 8" carbides and I liked them. As yamaholic said point and shoot little darting if any depending on conditions. The only thing I found with them if the snow had a light crust that you broke thru they were scary at speed. Which I think is caused from the deep keel
			I have a pair of ADV C&A skis with 6" Shaper bars and Berstron Ski savers.
I really like the Shaper bars, they wear real good. The Berstrom ski savers add and extra 1/4 to the keel and save the bottom of your skis from getting all chewed up. They cost $15 shipped?
