Need SRX Help!!!
ExpertXViper
Livonia, MI
K heres the deal I bought my SRX thats was long traveled when I got it, and I went back to all stock short travel shocks. Where I need help is the transfer rods cause the spacers I have, I dont know if there stock or from the A/M transfer rods. I tried looking at the Yami Fiche but in my eyes it just doesnt cut it. So what I need if possible, is a ACTUAL PICTURE of a STOCK transfer rod set-up from a 00-02 SRX. So I can compare the spacers. Any help is appreciated!!!! Thanks
Brett
crrider555@sbcglobal.net
there are 2 white spacers per rod
the thicker one is on the bottom from the factory but most people swap them around to get a little more transfer
Thanks Tom......Thats all I needed to know.
putting the thicker one on the top would be less transfer isnt it? means it would couple up faster
use a 2.5mm thick spacer on bottom of rods on 2000-02 srx. its right from the suspension manual, the stock thicker ones made the sled eat hyfax.
So use the 2.5mm on the bottom and the thicker one on top???? Or buy 2 more 2.5mm to use on top and bottom???? This is for a 01 SRX
