marinetech
Last year was the first year I put any amount of miles to speak of on my 98 srx. It is all stock , engine , carbs. and clutching. Compression is fine but the center cyld. likes to fowl plugs. Could it be that the stock jetting is to rich ? Any help in this matter would be great , I don't want to through parts at it , I'm used to the old sleds that were much simpler than this , the only carbs. I've messed with are mikuni round slides. Thanks , Dana
YAMMIEGOD3:16
DANA, NO WAY AROUND IT BUD. CARBS HAVE TO COME OFF. START AT THAT MIDDLE CARB. ALTHOUGH YOU MAY HAVE BAD REED, ALSO MIGHT BE COIL OR COIL WIRE. 3:16 (yammie tony)
seca
its a good idea to clean the carbs every season, but first do a ohms reading on the plug caps. if you do not get close to 5k--replace. what a diff it made to my 99 srx 700!!
marinetech
Should I lean the carbs. a little while I have them apart ?
If you lean it, make sure you are doing it where it is fouling. low mid etc. Also do plug and piston checks afterwards. Maxdlx
