Fro
I'm putting Viper rears in now & want to gain in the front also by flipping the mounts. It seems as though this will slightly offset the camber angle. Is it enough to bother messing with? Thanks, Fro.
Good question, as soon as my ummm....expensive new skid arrives, I'm going to be doing the mount flip/swap too.
Just did a search on flipping the mounts, seems the camber has to be adjusted after.
Fro
lol..thanks. makes sense. I was searching also. Tech had a "real world" procedure that sounds more realistic than the manual. Good luck with the skid swap. Once you see & feel the difference it will all be good.
dont forget to adjust your front to back ski pressure. doing this mod or adding long travel rear skid will increase pressure on the front of the ski and cause darting.
Fro
Are tou talking about adding those hyfax spacers under the ski rubber?
