SRX to Viper rears...What should pre-load be?
Fro
Howell, Mi
After putting in the rear/rear, it seems as though there could be a binding situation as the suspension moves. It's like the larger spring is too close to the mount. It gets better as I tighten it up. Now I have it set to 379.5mm the Viper spec for softest. I wanted to start there. I don't have it back in yet, so it may be fine. It just appears too close. Is the spec different when installed in an SRX? Thanks, Fro.
preload from another sled to yours is only a guide line. all sleds are different because of the amount of wear in the bushing, spring sag, your weight, fra setting, front end height difference. read the link below and it will explain how to set your ride height.
