installing new track. CHANGE BEARINGS?
onebad97
pennsylvania
Im installing a new track do i need to change bearings if not bad?should I? dealership said i should and there are 3 not in the chain case and Ill have about a $100.00 in 3 bearings.
With those miles I would just change the speedo side bearing as it is common for it to go out. If you think you are going to keep the sled for quite a few years, you could do the others. Pretty easy when it's apart.
