j.e.1975
Has anyone tried a polaris electric start clutch on a viper er. Will the polaris ring gear work, if not can you swap ring gears.
thanks
j.e.1975
thanks
j.e.1975
redsnake3
would have to do something with the starter if it dont work with the polaris clutch, because the polaris clutchs have the ring gear unremovable.
j.e.1975
Thanks. Unless somebody has already tried this I might be best to get a polaris clutch and compare it to the yamaha clutch. Any pics of your sled ?
thanks
j.e.1975
thanks
j.e.1975
I have a polaris p85 with electric start ring on it, is there something you need to measure or see on it? The ring is bolted on the back of the clutch like a yamaha.
j.e.1975
mrviper700
If it's not too much trouble some dimensions would be very helpfull. Ring gear width, outside diameter and the number of teeth. Also is it a wide or narrow roller clutch and what is the date on the cover. If possible a pic of the backside with the ring gear to see if the bolt pattern is even close.
thanks
j.e.1975
thanks
j.e.1975
