tempaflow on ported cylinders....
2001SRX=Fast
Manitoba,Canada
Would you run tempaflow on ported cylinders...? if soo what jets and if not what jets would you run for Winnipeg Maniotba Canada.
Heads up. I ran tempaflo on a ported 02 viper in Dauphin Manitoba. Key word RAN. It caused more problems than it solved... aka 2 pistons.
Stay far,far away from the tempa BLOWS.........................unless you like to keep replacing pistons. Your not going to gain enough from it to warrant the use of it, a properly dialed in srx and or viper for that matter is quite good on gas mpg, and you dont have to totally rethink your riding habits everytime you start up your sled.
I should add also that just because the sled is ported does not mean its gonna be a gas hog, the trail porting I do runs stock 2001 srx mains/jetting, this is with ported cylinders, machined heads and piston mods. I like the use of the 42.5 pilot jet, stock 3rd groove needle clip with both washers under the clip, stock 2001 mains.
Something most people dont think about is clutching and gas mpg go hand in hand with each other, if you have a lousy inefficent clutch set up, your sled is eating up fuel because your wasting the energy to be transferred to the track. Rolling resistance also plays a roll in gas mpg, dragging the track at the curve, too tight of a track tension, the addition of oversize wheels all play a role in gas mpg as well.
Tempa Blows have thier place on the touring sleds or something non hi performance like the old twins or a venture or something, but when they are added to a hi performance piped machine, you usually spend more in piston replacement then you save in gas!
Thank you Mr.viper you have been a great help. So i will give the stock jetting a run and see how it does... Mr.Viper what was the stock jets on a 01 srx??? and should i run stock jetting in winnipeg manitoba??
148.8/148.8/150 for 01 srx, I dont know what you have as far as porting, these are what I run in my engines. I would start off rich and work down to the sweet spot if you dont know anything about it.
