Help broken o-ring
rhoag
Appleton Wi
After cleaning my new (to me) sled up I started making adjustments to the M-10 suspension. I set the sag to 3.75 inches and shortened up the limiter strap to 3/4 holes. Then I was playing around and noticed the little O-Ring that is in the remote reservoir compression adjuster was ripped and half hanging out. I of coarse grabbed it and pulled it the rest of the way out...daaa. Anyway, the shock appears to be fine and has pressure. What do you guys/gals think? Does this hold the nitrogen...will I loose pressure with out this o-ring?
Thanks!
If you can load the sled up and take over to a Poo dealer and see what they say...Most Poo dealer service M-10's...I would definitely want that seal back in before moisture gets in...ouch!!!
If the local Polaris dealer can't help just call Fast directly.Everybody I've dealt with out there has been super, there number is:218-744-2107
