Precision Ski's
rather-b-sleddin
Carleton Place Ont.
Has anyone put a set of precision ski's off a bombardier on a Vmax. I have a 1999 Vmax. Are they a direct bolt on or are there any mods required?? Any info appreciated...
I put a set on my 99 Vmax... Although I was told by many to use Doo rubber blocks and they would bolt right up. It wouldn't work (angles and height were off)... I ended up using Yamaha rubber blocks and filling below block (hole cut out of aluminum saddle) with a wooden filler glued into place... this brings the rubber block height to the right level...
Look at the Yamaha set up and try to replicate with the correct height piece of wood filler..
I found Doo spindles are angled to the ground differently than Yamaha... which is why their blocks would not work...
