I was just wondering if the stock srx pipes would fit on a 02 MM 700 without any modifications to make them fit.
I don't think they will. The hoods are different between the two. You may have to cut part of the belly pan also.
-1CS
-1CS
Is the MM power valved..I don't think the will fit......But somebody else might correct me. I might want triple pipes for non power valve motor
I might have set of power inf center dumps for sell with EGT gauges and all the clutch weights and springs
Nick
Nick
No. They are totally different engines. Guys have put SRX pipes on Vipers but I have never heard of them trying it on the redheads.
if i get a minute, that is my next venture project.
change_up
It would be interesting to see the power gains that can be had from the SRX pipes. Some fabrication and modification would almost positively be needed. Could you do it? oh yea, would the power be as much of a gain as with Aftermarket pipes tailored to that engine? I am not an engine builder so cant answer that, but I hope to see the results if somebody ever does it.
