SRX warning light question
Gordy
Reedsburg,WI
I just put motor back in, got the coolant bled, started and ran for 3-5 min to circulate water and i have water temp light is flashing 1 long and 3 short. says in tech it is sensor short or open. after looking i have a wire plug green in color by the carbs which has no place to plug into. is this green plug relavant or is it a spare? any suggestion would be very helpful. THANK YOU GORDY
Green plug ???
That green plug goes into the bottom of the coolant rail, on the right side of the motor sitting on the sled. I think it is beside a downward hose. It should clear your code. It is the water temp sensor plug. ;)!
dennis the menance,
thank you for the reply,thats what i get for pulling the motor,waiting two weeks to reinstall. again thankyou gordy
