trapow33
I cooked my suspension on blue last year and have begun looking for a replacement. I'd like to put a better suspension in than what it had before. So far, I've found several ski-poo suspensions. But looking at my buddies mach 1, it doesn't look like his suspension would bolt up. What suspensions are compatible? Are most? Do I have to adapt in any way? thanks!
It's snowing out west already; let it snow...
yamaholic22
Well no suspension other than a yamaha proaction is going to bolt right up, but you can make basically any other suspension fit as long as you have the exact measurements taken from a sled that had that suspension. A template to use for transferring the measurements really helps as well.
